Knowledge Base Article
Does the ALTASMI_PARALLEL megafunction support execution of the 4BYTEADDREX instruction for EPCQ256 configuration devices?
Description
In the Quartus® II software version 13.0 SP1 and earlier, the ALTASMI_PARALLEL megafunction does not provide a way to issue the 4BYTEADDREX instruction to an EPCQ256 configuration device.  This instruction is required to exit 4-byte addressing mode once it has been entered via the 4BYTEADDREN instruction.
This is important only if using an Altera® device family older than the 28-nm generation (like Stratix® IV devices) to configure from an EPCQ256 configuration device. Device families older than 28-nm require the EPCQ256 configuration device to be in 3-Byte addressing mode to configure successfully.
Resolution
The following patch for the Quartus II software version 13.0 adds a port to the ALTASMI_PARALLEL megafunction that facilitates execution of the 4BYTEADDREX instruction.
This function is scheduled to be incorporated in a future verison of the Quartus II software.
Updated 4 months ago
Version 5.0
