Knowledge Base Article
Do Cyclone devices in the T100 package support LVDS channels?
Description
The EP1C3 device in the 100-pin TQFP package does not have any true differential receivers available.  LVDS is supported using emulated LVDS buffers.
For the EP1C3T100 device, LVDS is supported with the following data rates:
 - Tx identical to other Cyclone® devices with -6/-7/-8 performance of 640/640/550Mbps
 - Rx more conservative with 200Mbps across speed grades
Resolution
To use these emulated LVDS transmitters and receivers, assign the LVDS I/O standard in the Quartus II software.  The pins which are available as emulated LVDS transmitters or receivers may be seen in Pin Planner by using the "Show Differential Pin Pair Connections".
Updated 11 months ago
Version 3.0
