Knowledge Base Article
Designs with Error Correction Coding (ECC) Do Not Work After Subsequent Reset
Description
Some designs with ALTMEMPHY-based DDR, DDR2, or DDR3 SDRAM high-performance controllers do not work with the Enable Error Detection and Correction Logic option turned on.
This issue affects all designs that use DDR, DDR2, or DDR3 SDRAM high-performance controllers with the Enable Error Detection and Correction Logic option turned on.
Your design does not work properly in both simulation and hardware after the subsequent reset.
Resolution
None.
This issue will be fixed in a future version.
Updated 2 months ago
Version 3.0No CommentsBe the first to comment
