Knowledge Base Article
Cyclone® V SoC Pin-Out Table: Known Issues
Description
Issue 95669: In the Cyclone® V SoC (SE, ST, and SX) pin-out files with Revision 1.1 and lower, the SD/MMC clock pins are incorrectly labeled. You will notice the name mismatch between the pin-out file and Cyclone V Device Family Pin Connection Guidelines (PDF).  In the Pin Connection Guidelines, the clock pins are named SDMMC_FB_CLK_IN and SDMMC_CCLK_OUT. However, the pin-out file uses the outdated name SDMMC_CLK_IN and SDMMC_CLK.
When you cross-reference the pin names from the pin-out file to PCG, relate SDMMC_CLK_IN to SDMMC_FB_CLK_IN and SDMMC_CLK to SDMMC_CCLK_OUT.
Resolution
Updated 3 months ago
Version 2.0
