Knowledge Base Article
CvP Update Stress Tests Might Fail in Arria V GZ Designs that Include the Transceiver Reconfiguration Controller
Description
CvP update stress tests might fail when a Stratix V GX Hard IP for PCI Express IP Core design also includes the Transceiver Reconfiguration Controller IP Core. This hardware issue does not affect CvP initialization.
Resolution
For some systems, removing the Transceiver Reconfiguration
Controller IP Core from the system design and tying the Avalon Memory-Mapped
(Avalon-MM) interface_sel signal for each channel or
PLL to 1’b1 resolves this issue. The interface_sel signal is reconfig_to_xcvr[44] of
each channel or PLL. However, this workaround prevents you from
assigning different protocols to the 6 channels in a transceiver
bank. A comprehensive solution is under investigation.
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
