Knowledge Base Article
Critical Warning Displays if RapidIO IP Core System Clock and Reference Clock Have Same Source
Description
If the system clock and the reference clock for your RapidIO MegaCore function are driven by the same source, the Quartus II software issues a critical warning.
This issue has no design impact. The critical warning can be ignored.
Resolution
You can avoid the critical warning by cutting some of the nodes in the Synopsys Design Constraints File (.sdc). To obtain an .sdc compatible list of the nodes to be cut, refer to Altera solution rd07132010_207 at www.altera.com/support/kdb/solutions/rd07132010_207.html.
This issue will be fixed in a future version of the RapidIO MegaCore function.
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
