Knowledge Base Article
Critical Warning (136017): Ignored DISABLE_DA_RULE assignment to name <wildcard string> because the ACF assignment does not support wildcards
Description
Due to a problem in the Quartus® II software version 12.0 SP2 and earlier, you may see this warning if you use wildcards when specifying instances for a DISABLE_DA_RULE assignment.
Resolution
This warning can be safely ignored. The DISABLE_DA_RULE assignment does support wildcards when specifying instances.
This problem is fixed beginning with the Quartus II software version 12.1.
Updated 1 month ago
Version 2.0
