Knowledge Base Article
CPRI IP Core User Guide Requires Some Updates
Description
The CPRI MegaCore Function User Guide requires the following updates:
- The Include Vendor Specific Space (VSS) access through CPU interface parameter became the Include all control word access through CPU interfaces parameter in the CPRI IP core v14.0. The parameter function is unchanged.
- The
rx_fast_cm_ptrfield of theCPRI_CM_STATUSregister at offset 0x2C has a value in the range of 0x14 to 0x3F, and not 0x24 to 0x3F as listed erroneously in the register field description. - The
rx_state_holdfield of theCPRI_STATUSregister at offset 0x4 is not a held version of therx_statefield. Instead, when the value ofrx_statebecomes 0, the value ofrx_state_holdbecomes 1.
Resolution
The information in this erratum updates the information in the user guide.
This issue will be fixed in a future version of the CPRI MegaCore Function User Guide.
Updated 4 months ago
Version 4.0No CommentsBe the first to comment
