Knowledge Base Article
Configuration Issues with the SDI Audio Extract Parameter Editor
Description
You cannot configure your design in the SDI Audio Extract parameter editor if you do not turn on the Include Avalon-ST Interface parameter. You will get the following error message:
Error: test: Conduits cannot mix export signals with non-export signals. while executing "add_interface_port conduit_audio aud_ready ready Input 1" ("if" else script line 4) invoked from within "if { > 0 } { # Set interface properties add_interface aud_dout_clock clock sink set_interface_property aud_dout_clock ENABLED..." (procedure "my_elaboration_callback" line 28) invoked from within "my_elaboration_callback"
Resolution
To work around this issue, turn on the Include Avalon-ST Interface parameter.
This issue will be fixed in a future version of the SDI Audio Extract IP core.
Updated 1 month ago
Version 2.0
