Knowledge Base Article
Compilation fails if the MegaWizard Plug-In Manager creates transmitter PLLs that use SDI or CPRI with phase frequency detector (PFD) feedback turned off for Cyclone IV GX
Description
If you use the MegaWizard Plug-In Manager to create, at locations PLL_6 and PLL_7, transmitter PLLs that use SDI or CPRI with phase frequency detector (PFD) feedback turned off, compilation of the design fails with an error similar to the following:
Error: Can’t place the MPLL or GPLL PLL <tx pll name>
in the PLL location PLL_7 because the location operates on compensation
mode but the PLL supports only “no compensation” mode.
Resolution
Manually set PLL operation mode to no_compensation.
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
