Knowledge Base Article
Command-line DSE II compilation results are not visible in the DSE II GUI
Description
You initiated a compilation or design exploration with the Design Space Explorer (DSE) II command-line tool but cannot view the results in the DSE II GUI. The DSE II GUI cannot show the results because a compilation name (--group-id) was not specified for the command-line compilation.
Resolution
Edit the <revision>.dse file located in the project directory to add or change the group_id argument (group_id = <compilation name>. The default name is dse1_<revision_name> if
a compilation name is not explicitly specified.
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
