Knowledge Base Article
Clean Build Causes Build Failure
Description
Performing a clean build on a Nios II IDE project that contains a hardware accelerator can cause the next build to fail in the IDE, because the clean build erroneously deletes a file required by the C2H Compiler.
Resolution
Do not perform a clean build on projects that use hardware accelerators. If you have already performed a clean build, recompile with option Build software, generate SOPC Builder system, and run Quartus II compilation to regenerate the necessary files.
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
