Knowledge Base Article
Cannot Reopen SDI II Wrapper File in MegaWizard
Description
The MegaWizard Plug-In Manager does not recognize the Serial Digital Interface (SDI) II top level wrapper file when you choose Edit an existing custom megafunction variation. The dialog box displays the following message:
Megafunction name: Uninstalled/Unknown MegaWizard
You are not able to edit your design using the SDI II parameter editor.
Resolution
To overcome this issue, follow these steps:
- Open the generated wrapper file.
- Change the megafunction name (line 1) from %SDI II v13.0sp1% to %SDI II v13.0%.
This issue will be fixed in a future version of the SDI II MegaCore function.
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
