Knowledge Base Article
Cannot Regenerate RapidIO MegaCore Function with Read-Only .qip File
Description
If you try to edit or regenerate a RapidIO MegaCore function whose previously generated .qip file has permissions set to read-only, the MegaWizard Plug-In Manager hangs when trying to generate the new version of the MegaCore function.
This issue affects all RapidIO variations.
Resolution
To avoid this issue, modify the permissions for the RapidIO MegaCore function .qip file to ensure it is writable before editing the RapidIO MegaCore function.
This issue will not be fixed in a future version of the RapidIO MegaCore function.
Updated 11 months ago
Version 3.0
