Knowledge Base Article
Can I use a different AES key to generate encryption PR(Partial Reconfiguration) with non-volatile, as well Static region with non-volatile in respect of Arria10 ?
Description
No. It is not feasible.
  • Arria10 can only store 2 type keys, volatile key and non-volatile key.
  • If PR region and static region use same type of key, then customer can only use 1 key.
  • If PR region uses volatile key, static region uses non-volatile key, then customer can use 2 keys. Vice versa.
Updated 11 months ago
Version 3.0
