Knowledge Base Article
Can a 9-transceiver channel Arria V GT device support an Rx only channel that already has four 6.144-Gbps duplex or Tx channels?
Description
No, a 9-transceiver channel Arria® V GT device cannot support an Rx only channel that already has four 6.144-Gbps duplex or Tx channels.
Due to a bug in the Quartus® II software versions 13.1 and earlier, the Fitter will not produce an error message for the configuration above.
Resolution
This problem is fixed in Quartus II software version 13.1 and an error message is produced with the above illegal configuration.
Updated 11 months ago
Version 2.0
