Knowledge Base Article
Build Command Not Functional for BSPs Created With the Nios II SBT
Description
The build option in the Nios II IDE menu does not rebuild BSPs imported to the IDE.
Resolution
The Nios II SBT for Eclipse can both build and debug projects created on the command line. The Nios II SBT for Eclipse is the preferred tool for debugging Nios II SBT projects.
For information about the Nios II SBT for Eclipse, refer to the Getting Started with the Graphical User Interface chapter of the Nios II Software Developer\'s Handbook.
In the Nios II IDE, you can build the BSP by building the associated application project.
Updated 1 month ago
Version 2.0
