Knowledge Base Article
Board Skew Analysis Is Incorrect for Arria V and Cyclone V Devices
Description
This problem affects DDR2 and DDR3 products.
Board skew analysis of the DQS to CK timing relationship is performed as part of the Report DDR command. The calculation for the setup and hold margin of the DQS to CK relationship is incorrect.
Resolution
The workaround for this issue is to generate your external
memory interface, and then make the following changes to the interface_name<>_if0_p0.sdc file
in the UniPHY IP submodules folder:
- Find the DQS vs CK timing constraints in
the .sdc file. This is the
set_output_delayconstraints in theDQS vs CK PATHsection of the file. - Modify the
term in the-maxand-minconstraints from being added to being subtracted. - Swap
(minCK_DQS_skew)for(maxCK_DQS_skew)in the constraints.
The correct constraints are as follows:
set_output_delay -add_delay -clock [get_clocks ]�
-max [{interface_name}_round_3dp [expr (CK) - (DQSS)� *(CK)
- (minCK_DQS_skew) ]] �
-min [{interface_name}_round_3dp [expr (DQSS)*(CK)� -(maxCK_DQS_skew)
After you implement this workaround, the TimeQuest will analyze
the DQS to CK relationship correctly. You might not see a change
in the reported setup and hold margin, if your minCK_DQS_skew is
the negative of the maxCK_DQS_skew.
This issue will be fixed in a future version.
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
