Knowledge Base Article
Auto-Negotiation Could Not Complete in 1000BASE-X PCS Function
Description
When you enable auto-negotiation on the 1000BASE-X PCS function and link synchronization is acquired, the auto-negotiation process could not complete.
This issue affects 1000BASE-X PCS function designs with the auto-negotiation option enabled.
Resolution
To avoid this issue, set the HD bit in the dev_ability register
to 1.
This issue will be fixed in a future version of the Triple Speed Ethernet MegaCore function.
Updated 23 days ago
