Knowledge Base Article
Audio Clock Contains High Jitter
Description
The audio clock, aud_clk_out, generated by the
SDI Audio Extract MegaCore function contains high jitter. The SDI
Audio Extract MegaCore function generates aud_clk_out at
a frequency of 3.072 MHz, that is synchronous to the receiving video
data, but contains high jitter.
This issue affects all SDI Audio Extract configurations.
The generated audio signal contains high jitter.
Resolution
None.
The user is responsible to generate a clean and synchronous frequency of 3.072 MHz.
Updated 2 months ago
