Knowledge Base Article
Assign LVDS I/O standard-supported pins in right I/O banks of Arria V A1/A3/C3 devices as PLL clock input pins only
Description
If you use the Quartus II software version 13.0 DP2 or 13.0 SP1 to create a design that targets an Arria V A1, A3 or C3 device, and you use the LVDS I/O standard-enabled pins in the right I/O bank for purposes other than as phase-locked loop (PLL) clock input pins, the resulting FPGA hardware might not function properly.
Resolution
You must assign the LVDS I/O standard-enabled pins in the right I/O bank as PLL clock input pins only. The Quartus II software version 13.0 DP2 or 13.0 SP1 does not issue an error message for incorrect assignments to these LVDS I/O standard-enabled pins.
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
