Knowledge Base Article
"Assign Base Addresses" causing memory overlap in Qsys
Description
In Qsys, when you choose System > Assign Base Addresses, the software might assign overlapping base addresses and display an error message such as:
slave0.s0(0x0..0xfff) overlaps slave1.s0(0x0..0xfff)Resolution
You must manually change the overlapped base address value to a legal value in the Base tab.
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
