Knowledge Base Article
Arria V GT CPRI IP Cores at Data Rate 9.8 Gbps Do Not Provide Transceiver Status on gxb_rx_pll_locked and gxb_rx_freqlocked Signals
Description
In CPRI IP core variations that target an Arria V GT device and that run at a CPRI line rate of 9.8 Gbps, the transceiver status output signals gxb_rx_pll_locked and gxb_rx_freqlocked signals are always held low.
Resolution
This issue has no workaround. Ensure you do not rely on these two status flags in these CPRI IP core variations.
This issue is fixed in version 13.1 of the CPRI MegaCore function.
Updated 1 month ago
Version 2.0
