Knowledge Base Article
AN 625: Stratix® V Device Design Guidelines: Known Issues
Description
Issue 145244: Version 1.0
Guideline 53 for nIO_PULLUP is not correct. The option to disable the internal pull-up resistors is not supported on Stratix V devices. The nIO_PULLUP pin must be connected to GND.
Issue 145253: Version 1.0
Guideline 32 for setting the power-on reset (POR) time is not correct. It states power sequencing is not a requirement. This is incorrect - refer to Power Management In Stratix V Devices (PDF) for information on power sequencing requirements.
Updated 3 months ago
Version 3.0No CommentsBe the first to comment
