Knowledge Base Article
Altera QDR II Memory Model Behaves Differently Than Other Vendors Memory Models During Concurrent Transactions
Description
This problem affects QDR II products.
During concurrent transactions where read and write commands to the same address occur on the same clock cycle, the expected preload value is overwritten by the concurrent write command.
If you issue write–read–write commands to the same address with certain TCL-TCWL combination settings, the Altera memory model delivers the most recent information associated with the specified address location.
Resolution
There is no workaround for this issue.
This issue will not be fixed.
Updated 3 months ago
Version 3.0No CommentsBe the first to comment
