Knowledge Base Article
altera_fp_functions compare function generates top level file without required port
Description
When you create compare functions for the floating-point IP cores in the 13.1 Quartus® II software release, the top-level .vhd file is generated without the required "b" port. This .vhd file error only occurs when creating compare functions; other functions from altera_fp_functions are not affected.
Resolution
This issue is fixed in the 14.0 Quartus II software release.
In the 13.1 Quartus II software release, when you create a compare function called cmp, the software generates a top level file called cmp.vhd; this file is missing the required "b" port. You can modify cmp.vhd as follows to include required "b" port:
entity cmp is
port (
clk : in std_logic := \'0\'; -- clk.clk
areset : in std_logic := \'0\'; -- areset.reset
a : in std_logic_vector(31 downto 0) := (others => \'0\'); -- a.a
b : in std_logic_vector(31 downto 0) := (others => \'0\'); -- b.b
q : out std_logic_vector(0 downto 0) -- q.q
end entity cmp;
architecture rtl of cmp is
component cmp_0002 is
port (
clk : in std_logic := \'X\'; -- clk
areset : in std_logic := \'X\'; -- reset
a : in std_logic_vector(31 downto 0) := (others => \'X\'); -- a
b : in std_logic_vector(31 downto 0) := (others => \'X\'); -- b
end component cmp_0002;
begin
cmp_inst: component cmp_0002
port map(
clk => clk, -- clk.clk
areset => areset, -- areset.reset
a => a, -- a.a
b => b, -- b.b
q => q -- q.q
);end architecture rtl; -- of cmp
Updated 2 months ago
Version 2.0
