Knowledge Base Article
ACDS 15.0 DisplayPort IP core fails to generate a time-limited programming file (.sof)
Description
Quartus® II software v15.0 DisplayPort IP core is missing an OpenCore Plus (OCP) file, preventing the Quartus II software from generating a time-limited programmng file (.sof) for hardware evaluation.
Resolution
To work around this issue, follow these steps:
1. Download the OCP file, bitec_dp.ocp, from the following link :
- ACDS 15.0 DisplayPort IP Core OCP file
2. Place it in the \'ip/altera/altera_dp/src/bitec_dp/common\' directory under the Quartus II software installation folder before you run the Quartus II software compilation.
This issue is planned to be fixed in a future version of the Quartus II software.
Updated 4 months ago
Version 4.0No CommentsBe the first to comment
