Knowledge Base Article
*** Fatal Error: Stack Overflow, TIS_RE_DELAY_TREE_TRANSIENT_NODE
Description
Due to a problem in Quartus® II software version 12.0 SP2 or earlier, you may see this error during the Fitter if your design has physical synthesis enabled for compilation.
Resolution
A patch is available to fix this problem for the Quartus II software versions 12.0 SP2. Download and install device patch 2.dp10 from the related solution below.
Alternatively, if you are using device patch 2.dp9 and cannot use device patch 2.dp10, download and install device patch 2.dp9c from the appropriate links below. You must install device patch 2.dp9 before installing device patch 2.dp9c.
- Download the version 12.0 SP2 patch 2.dp9c for Windows (.exe)
- Download the version 12.0 SP2 patch 2.dp9c for Linux (.tar)
- Download the Readme for the Quartus II software version 12.0 SP2 patch 2.dp9c (.txt)
This problem is fixed beginning with the Quartus II software version 12.1.
Related Articles
Updated 4 months ago
Version 4.0No CommentsBe the first to comment
