Knowledge Base Article
*** Fatal Error: Segment Violation: faulting address=(nil), PC=0x7fffd615e2af : 0x7fffd615e2af: synth_vrfx2!vrfx2_get_verilog_input_version(BASEX_SRC_FILE*, HDB_NAMESPACE*) + 0x3f
Description
Due to a problem in the Quartus® Prime Pro Edition Software version 23.4, you may get this fatal error when synthesizing your design.
This error occurs when setting your SEARCH_PATH assignment with a path containing sequences like "../../", which navigates back several folders and then into others.
Resolution
To work around this problem , provide the direct path without navigating back to other directories.
This problem was fixed in the Quartus® Prime Pro Edition Software version 24.1.
Updated 1 month ago
