Knowledge Base Article
*** Fatal Error: Access Violation at 0X00007FFEA1CA07A4
Description
Due to a problem in the Quartus® Prime software version 16.1 , you may see this internal error when archiving your design with the "File Set" options:
- Service Request
- Service Request with incremental compilation database
- Compilation Database and output
Module: quartus.exe
Stack Trace:
0x207a3: HDB_NAMESPACE::set_compile_status 0x17 (DB_HDB)
0x2019c: qtk_get_output_persona_filename 0xbc (db_qtk_tcl)
Resolution
To work around this problem, use the default archiver "File Set" setting of "Source control".
This problem is scheduled to be fixed in a future release of the Quartus Prime software.
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
