Knowledge Base Article
*** Fatal Error: Access Violation at 0X00000000161F28DA
Description
You may receive an internal error when attempting to program an Active Serial configuration device (EPCS or EPCQ device) using the Serial Flash Loader and a .jic file, using the Quartus® II software version 12.1.  The internal error will contain the following text:
Module: quartus.exe
Stack Trace:
0x1428d9: PGMIO_FLASH_MANAGER::sfl_get_chain_longest_program_utime 0x79 (pgm_pgmio)
0x77dfb: PGME_PROGRAMMER::get_max_siid 0x691b (sys_mdb)
0x880ce: PGME_PROGRAMMER::get_jic_device_name_from_id 0xe4e (sys_mdb)
0x8aceb: PGME_PROGRAMMER::get_jic_device_name_from_id 0x3a6b (sys_mdb)
Resolution
Use version 12.0 of the Quartus II Programmer
This is scheduled to be fixed in a future release of the Quartus II software.
Updated 17 days ago
Version 2.0
