Knowledge Base Article
# ** Error (suppressible): (vsim-10000) <simulation directory>/sim/<IP name>.v(61): Unresolved defparam reference to 'scfifo_component' in scfifo_component.add_ram_output_register.
Description
Due to a problem in the Quartus® Prime Standard Edition Software version 18.1 and earlier, you may see this error message if you run the nativelink simulation in the Modelsim simulator. This is because you have a FIFO IP in your design, and this IP does not support VHDL simulation.
Resolution
To work around this problem, change the format for the output netlist from VHDL to Verilog HDL in:
Assignment -> Settings -> Eda Tools Settings-> Simulation ->  Format for output netlist before you run the native link simulation.
Updated 1 month ago
Version 3.0
