Knowledge Base Article
# ** Error: _1200mv_85c_slow.vho(13670): Illegal target for signal assignment. # ** Error: _1200mv_85c_slow.vho(13670): (vcom-1136) Unknown identifier "ww_dataout".
Description
Due to a problem in the Quartus® II software version 12.0 and later, you may see this error message when compiling your gate-level VHDL netlist in the ModelSim simulator. This error occurs if your design constains an ALTDDIO_OUT instance.
Resolution
To work around this problem, turn off the Maintain hierarchy option for the EDA Netlist Writer by following the steps below:
  1. Select Settings from Quartus II Assignments menu
  2. In the Settings dialog box, click on Simulation under EDA Tool Settings in the Category pane
  3. Click on More EDA Netlist Writer Settings
  4. Turn off the Maintain hierarchy option
This problem is scheduled to be fixed in a future release of the Quartus II software.
Updated 11 months ago
Version 3.0
