De2-115 remove the default project
- 2 years ago
The DE2-115 is a pretty old board, around since 2012; I got mine back in 2015 and it uses an EPCS64 device for program storage.
I use QuartusII 16.0 for development it it works exactly as the documentation specifies.
When did you get your board, and what version of Quartus are you using?
Are you aware of: https://www.terasic.com.tw/cgi-bin/page/archive.pl?Language=English&CategoryNo=165&No=502#contents
You are probably compiling your project into a .sof file and downloading it directly into the FPGA configuration RAM.
It will be active UNTIL you power cycle the board as the RAM configuration does not persist without power.
At power up the configuration EPROM will be read and loaded into the device (the boards are normally setup to do this).
So that is why if you power cycle the board the 'default' configuration stored in the config EPROM reappears.
What you need to do, besides compiling your project to a .sof file, is use the Quartus tool quartus_cpf to generate a config EPROM .jic
which you can then download to the EPROM.
For example I run:
quartus_cpf -c DESIGN.cof
where DESIGN.cof contains:
<?xml version="1.0" encoding="US-ASCII" standalone="yes"?> <cof> <eprom_name>EPCS64</eprom_name> <flash_loader_device>EP4CE115</flash_loader_device> <output_filename>DESIGN.jic</output_filename> <n_pages>1</n_pages> <width>1</width> <mode>7</mode> <sof_data> <user_name>Page_0</user_name> <page_flags>1</page_flags> <bit0> <sof_filename>DESIGN.sof</sof_filename> </bit0> </sof_data> <version>4</version> <options> <map_file>1</map_file> </options> </cof>
And you will want to add the Altera serial flash loader module into your top level module as well (assuming verilog here):
// Altera Serial Flash Loader module // Allows external JTAG access to the serial config eeprom for programming sfl sfl ( .asdo_in (1'b0), // not used .dclk_in (1'b0), // not used .ncso_in (1'b0), // not used .noe_in (1'b0), // always enabled .asmi_access_granted (1'b1), // external JTAG access always .asmi_access_request (), // not used .data0_out () // not used );
- mitsvoid2 years ago
Hi, Thank you for the prompt reply. I will check it and will update.
