Why the device of quartus_cpf command is illegal?
Above picture show the setting in the Convert Programming Files GUI.
I want to translate it to TCL commands.
The TCL command is as follow picture.
Unfortunately, tool tell me that device is illegal as follow picture.
Command:
pof_convert.tcl file:
Error message:
- YuanLi_S_Intel
Can you try the following workaround? Seems like we have issue on v13.1 and earlier
- NuvKFC
Contributor
Hi YuanLi_S_Intel
Thank you, YuanLi_S_Intel, very much.
The generated pof file name is different every time.
How to configure the cof file's pof file name by using "quartus_cpf -c <cof file>" command?
- ak6dn
As noted in the earlier post, on Quartus 13.0sp1 I use a configuration file .cof and run quartus_cpf -c design.cof and that works just fine.
You just have to put all the parameters in the .cof file and not on the command line.
Contents of my design.cof file:
<?xml version="1.0" encoding="US-ASCII" standalone="yes"?> <cof> <eprom_name>EPCS4</eprom_name> <flash_loader_device>EP2C20</flash_loader_device> <output_filename>design.jic</output_filename> <n_pages>1</n_pages> <width>1</width> <mode>7</mode> <sof_data> <user_name>Page_0</user_name> <page_flags>1</page_flags> <bit0> <sof_filename>design.sof</sof_filename> </bit0> </sof_data> <version>4</version> <options> <map_file>1</map_file> </options> </cof>- NuvKFC
Contributor
Hi ak6dn
Thank you, ak6dn, very much.
I will try to use Convert Programming Files GUI to generate the cof file.
Do you mean that?
- ak6dn
If I recall correctly, I think I used that tool the first time to build it in a GUI.
Now I just modify/build it using a text editor copy/paste/edit.
The .cof file is a simple XML format text file, so a text editor works just fine.
- NuvKFC
Contributor
Hi ak6dn
Because the generated pof file name and sof file are different every time, could I use the variable in the cof file?
