8 years agoWhy Quartus Prime Standard Edition ignores XCVR_REFCLK_PIN_TERMINATION assignment
Hi, I am trying to find error in design using Arria 10 transceivers and during the analysis of the Fitter report I found, that according to the ignored Assignments sheet, all XCVR_REFCLK_PIN_TERMI...
8 years agoHi,
XCVR_REFCLK_PIN_TERMINATION is ignored because this setting is no longer applicable to Arria 10 Device. For Arria 10 XCVR, the correct XCVR refclk setting is XCVR_A10_REFCLK_TERM_TRISTATE. The setting can accept 2 value. XCVR_S10_REFCLK_TERM_TRISTATE TRISTATE_OFF is used for AC coupled reference clock inputs XCVR_S10_REFCLK_TERM_TRISTATE TRISTATE_ON is used for DC coupled reference clock inputs You can always refer to Arria 10 Transceiver PHY User Guide doc to find out more on the correct setting implementation. https://www.altera.com/documentation/nik1398707230472.html Thanks. Regards, spdl2001 (This message was posted on behalf of Intel Corporation)
