10 years agoWhat is the best Floating number method?
Hello friends... I want to know what is the efficient code to implement this equation : 1/4 ( x+y) + 1/2 However, inputs are integers , and the output will be also rounded to integer. Bu...
10 years ago --- Quote Start --- use fixed point. Its just integer with an offset (so easily implemented in an FPGA). --- Quote End --- yes use fixe point. just add x + y then add half of result and truncate 2 LSBs I am assuming you want to add x+y, divide by 4 then round
