12 years ago
What is mean by output port has no driver???
I'm currently a final year student. Could anyone please help me to solve this problem. When i key in the verilog code, there are somes warning say that my output port has no driver. Can I know what is the meaning?
Here is my code.# ############################################################################################################
module FIR_interface(reset,clk,chipselect,writedata,readdata,x,selA,ld,Q);
input reset,clk,chipselect;
input [15:0]writedata,Q;
output [15:0]readdata;
output [7:0]x;
output ld;
output [2:0]selA;
reg [7:0]x;
reg [2:0]selA;
reg ld;
reg [15:0]readdata;
reg [3:0] c;
always @(posedge clk)
begin
if (reset==1)
readdata <=16'd0;
else if(chipselect)
begin
for(c=0;c<<4'd10;c=c+1)
begin
case (c)
(0|2|4|6|8) :
begin
x <= writedata[7:0];
selA <= writedata[10:8];
ld <= writedata[15];
end
(1|3|5|7|9) :
readdata[15:0] <= Q;
endcase
end
end
end
endmodule # ############################################################################################################
    What are you hoping for from your 'for' loop? I suspect it is not doing what you want.
    Your code is instantiating 10 blocks of logic, one for each iteration of your for loop. However, it's not correct and, as I said, I suspect it's not what you want anyway.
    Give a brief description of what it is you're trying to do....
    I also it is wrong><
    actually this is the interface of my fir filter code.
    Here's my fir filter verilog..
    module toplvl (x,selA,clk,ld,rst,Q);
    input [7:0]x;
    input [2:0] selA;
    input clk,ld,rst;
    output [15:0] Q;
    wire [7:0] s1;
    wire [15:0] s2,s4;
    sel1 A1(selA,s1);
    multiplier A2(x,s1,s2);
    register A4(clk,ld,rst,s2,Q);
    endmodule
    module multiplier(x,b,p);
    input [7:0] x,b;
    output [15:0] p;
    assign p=x*b;
    endmodule
    module sel1(selA,b);
    input [2:0] selA;
    output [7:0] b;
    reg [7:0] b;
    always@*
    case(selA)
    0: b=8'd2;
    1: b=8'd4;
    2: b=8'd6;
    3: b=8'd8;
    4: b=8'd10;
    default: b=8'd0;
    endcase
    endmodule
    module register(clk,ld,rst,p,Q2);
    input clk,ld,rst;
    input [15:0] p;
    output [15:0] Q2;
    reg [15:0] Q2;
    always@(posedge clk)
    if (rst==1) Q2<=p;
    else if (ld==1)
    Q2=p+Q2;
    endmodule
    after that i hv to create an interface for it... cause I want to load it on DE2 board.
    I don't know what you're asking for. This forum is for specific problems, which need specific questions...
