Warning: (vsim-3473) Component instance "mem_map : system_mem" is not bound.
I try to compile and simulate the design files you attached. However, I can't access to work.keccak_globals as you didn't provide the library file.
I notice both component and entity names are same (system_mem) should be not a problem. May be you can try in testbench like below:
for mem_map : system_mem use entity work.system_mem;
begin
mem_map : system_mem port map(clk,rst_n,enR_mem,enW_mem,addr_mem,data_to_mem_mem,data_from_mem);
OR
begin
mem_map : entity work.system_mem port map(clk,rst_n,enR_mem,enW_mem,addr_mem,data_to_mem_mem,data_from_mem);
May also take a look at this:
Component Not Bound :
Symptoms:
- Warning: (vsim-3473) Component instance "fifo_receiver : fifo" is not bound.
- Signals coming in from a component remain unsigned.
Causes:
When simulating, a component used in the design could not be found.
Solution:
- Ensure that the component declaration matches the entity declaration exactly in the component file.
- Ensure all files needed for the design have been compiled.
- Check to make sure your directories are what you think they are and that your files are all in the same directory.
- In a few cases, a component might be optimized out during the simulation causing this error. If everything about appears right, simulate with the -novopt command.
**May check on this link at the component declaration section as well.
Sheng
p/s: If any answer from community or Intel support are helpful, please feel free to mark as solution and give Kudos.
