15 years agoHello fpgaGuy,
there is only one kind of error message left. An explanation follows at the end of this thread. Warning: PLL "PLL4:PLL4_inst|altpll:altpll_component|PLL4_altpll:auto_generated|pll1" input clock inclk[0] may have reduced jitter performance because it is fed by a non-dedicated input Info: Input port INCLK[0] of node "PLL4:PLL4_inst|altpll:altpll_component|PLL4_altpll:auto_generated|pll1" is driven by ClkCtrl:ClkCtrl_inst2|ClkCtrl_altclkctrl_7ji:ClkCtrl_altclkctrl_7ji_component|wire_clkctrl1_outclk which is OUTCLK output port of Clock control block type node ClkCtrl:ClkCtrl_inst2|ClkCtrl_altclkctrl_7ji:ClkCtrl_altclkctrl_7ji_component|clkctrl1 explanation: FPGA: Cyclone IV E - EP4CE115F23I7 Deticated Input Clock Pin of the FPGA: Pin A12 = CLK8 -- First PLL ------------- PLL2_inst : PLL2 PORT MAP ( areset => ResSys, inclk0 => CLK, -- 50 MHz c0 => Clk_50_E6_0_Pre, -- 50 MHz --> Clock Control Block c1 => Clk_87_5_E6_0, -- 87,5 MHz locked => PLL2_Locked ); Clock Control Block ------------------ ClkCtrl_inst2 : ClkCtrl PORT MAP ( inclk => Clk_50_E6_0_Pre, outclk => Clk_50_E6_0 ); Second PLL ----------- PLL1_inst : PLL PORT MAP ( areset => PLL2_Locked, inclk0 => Clk_50_E6_0, -- 50MHz c0 => Clk_125_E6_180, -- 125 MHz/ 180° c1 => Clk_125_E6_0, -- 125 MHz/ 0° locked => PLL1_Locked ); Third PLL --------- PLL4_inst : PLL4 PORT MAP ( areset => PLL2_Locked, inclk0 => Clk_50_E6_0, -- 50 MHz c0 => Clk_64_166667_E6_0, -- 64,16667 MHz/ 0° locked => PLL4_Locked ); Any idea what`s the reason for the warning message? BR, Carsten
