Here's my new code to have a large hold time:
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
entity ctrl is
port(
data : out std_logic_vector(7 downto 0);
wen : out std_logic := '0';
addr : out std_logic_vector(14 downto 0):=(others=>'0');
clk : in std_logic);
end ctrl;
architecture rtl of ctrl is
signal step : integer := 1;
signal hold : integer := 0;
begin
process(clk)
begin
if clk'event and clk='1' then
if step<5 then
if hold=10 then
step <= step+1;
hold <= 0;
end if;
hold <= hold+1;
wen <= '1';
else
wen <= '0';
end if;
data <= "00000001";
addr <= std_logic_vector(to_unsigned(step, addr'length));
end if;
end process;
end rtl;
Now addresses 1 and 2 are equal to 1 when others are 0. I don't understand what's happening.
