ZKhan1
4 years agoVHDL Package not detected by Modelsim
Hi all ,
I am using Quartus Prime ver 16.0 for compilation of my vhdl project files , the project compiles fine without any errors , but when i start simulation the Modelsim cantt seem to find my ...
- 4 years ago
Spelling difference? audio_codec_i2c_pkg vs. audio_codeci2c_pkg
SyafieqS
4 years agoHi Ahmed,
Looking back at your message, I see you are using vmap command. Use command vmap -c in the command-line window to copy the modelsim.ini file from the installation directory to the current working directory and see if the libraries mapping, startup file and default setting issue can be resolved instead of vmap only. If you do not use this command, all library mappings will be made to the modelsim.ini file in the installation directory. Altera recommends that you use vmap -c at the start of every new project.
Let me know any update.
