VHDL Package not detected by Modelsim
- 4 years ago
Spelling difference? audio_codec_i2c_pkg vs. audio_codeci2c_pkg
Ahmed,
Let me know if there is any update or concern on this
- ZKhan14 years ago
This is output of verror 19 :
vsim -t 1ps -L altera -L lpm -L sgate -L altera_mf -L altera_lnsim -L cycloneive_ver -L cycloneive -L rtl_work -L work -L Fir_left_ch -voptargs="+acc" tb_audio_ctrl_Top.vhd
# vsim -t 1ps -L altera -L lpm -L sgate -L altera_mf -L altera_lnsim -L cycloneive_ver -L cycloneive -L rtl_work -L work -L Fir_left_ch -voptargs=""+acc"" tb_audio_ctrl_Top.vhd
# Start time: 19:01:11 on Mar 16,2022
# ** Error: (vsim-19) Failed to access library 'tb_audio_ctrl_Top' at "tb_audio_ctrl_Top".
# No such file or directory. (errno = ENOENT)
# Error loading design
# Error: Error loading design
# Pausing macro execution
# MACRO ./Audio_FIR_filter_run_msim_rtl_vhdl.do PAUSED at line 76
verror 19
# common Message # 19:
# The specified library could not be accessed at the specified location.
# Verify that the directories in the path exist and have the proper access
# permissions and that the "_info" file (with proper access permissions)
# exists. This message might be preceded or followed by another message
# that gives more information about the problem.
# The vlib command creates a ModelSim library. The vmap command creates
# the map from a logical library name to the physical library (directory).
# Use the vmap command without arguments to find out how all the libraries
# are mapped. In the absence of a mapping, the library is searched for in
# the current working directory.
# One way this problem can occur is if the mapping for the library in your
# modelsim.ini file contains an environment variable that is not set
# in your environment.
