17 years ago
VHDL code for Left Shift register
Hello All.. I'm new to VHDL and have found myself stuck
I have problem in my code. I have created code for 8 bit shift register left..
ie my input is 11001011
then in
1st clock :- output should be :- 10010110
2nd clock :- output should be :- 00101100........to last clock
8th clock :- output should be :- 00000000
I can make a right shift using example code as follows and it works fine:
Data_Int<='0' & Data_Int(7 downto 1);
but when I try to following it gives me errors:
Data_Int<=Data_Int(6 downto 0) & '0';
7 errors:
Warning: No output dependent on input pin "DataIP[1]"
down to
Warning: No output dependent on input pin "DataIP[7]"
and when I simulate it Data_Int just goes to 1 and stays there.
Here's my full code listing. Any help would be appreciated thanks.
LIBRARY ieee;
USE ieee.std_logic_1164.all;
ENTITY shift IS PORT(
Clk : IN std_logic;
DataIP : IN std_logic_vector(7 downto 0);
DataOP : OUT std_logic;
load : IN std_logic;
rst : IN std_logic;
shift_out : IN std_logic);
END shift;
ARCHITECTURE behavioural OF shift IS
SIGNAL Data_Int : std_logic_vector(7 downto 0); --internal signal
BEGIN
PROCESS(Clk,load,shift_out,Data_Int)
BEGIN
IF(Clk'EVENT AND Clk='1')THEN
IF(rst='1')THEN
Data_Int<="00000000";
--if reset clear Data_Int and DataOP
ELSIF(load='1')THEN
Data_Int<=DataIP; --if load then load data from external
ELSIF(shift_out='1') THEN
Data_Int<='0' & Data_Int(7 downto 1); --if shift then shift it right
--Data_Int<=Data_Int(6 downto 0) & '0'; --if shift then shift it left
END IF;
--ELSE
-- Data_Int<=Data_Int; --all other conditions
END IF;
--could put DataOP<=Data_Int(0); here
END PROCESS;
DataOP<=Data_Int(0); --signal assignment outside process
END behavioural;
