12 years agoIf you instantiated SignalTap in your design directly using megawizard, you should be able to use the Input Port type still. In your simple case, you can connect NEW_DATA_PS to the storage_enable port. I tried it with a simple useless example as shown below and compiled successfully.
module one_wire (
input i,
output o
assign o = i;
stp_test stp_test_inst (
.acq_clk ( i ),
.acq_data_in ( {i} ),
.acq_trigger_in ( {i} ),
.storage_enable ( i )
endmodule What is it different from yours fundamentally?
