ThomasTessier
3 years agoUsing 2 inputs to Clock MUX doesn't result in correct answer
I have a design were I am trying to use the Input Clock MUX to Switch between two input pin clock ports. The PLLs are in platform designer and I get the following warning:
Warning: test_system_qsy...
ThomasTessier
3 years agoThe real design has lots of clocks, but this was happening on a design where there is the ALTCLKCTRL block and one PLL with all signals coming from the IO; that is it 2 IP blocks and connections. I need these PIN assignments as that is what I have access to on the Development Board; so they are not changing.
Let me package up the example and attach it to this case. It is so trivial it should work but I am baffled why the tool cannot do this. This might take me today to get approval to move this test design out of our secure area. Sorry don't have access to Quartus anywhere else for this project.
TomT...
ThomasTessier
3 years agoHere is the simple testcase which fails in FITTER as show above.
Any idea why this fails???
TomT...
