10 years agoUnable to intialize constant using data from a file(ModelSim 10.3, Quartus Prime15.1)
Hello, I am facing two problems with loading content from a file in VHDL. The file containts 32bit fixed point values and in each line are two values. The whole file is about 60000 lines long. I h...
10 years ago --- Quote Start --- Hm, I found a problem with the array index which solved the file loading problem in ModelSim. But that Quartus does not support textio is bad, so I will have to change my Matlab script to produce VHDL code. Are their any information available when Quartus will support textio? --- Quote End --- No info. I requested an enhancement update in 2009 and Im still waiting. Dont expect it anytime soon, even though Xilinx have supported it for about 10 years! You can initialise a ram with a .mif file.
