12 years agoUART and MODELSIM ALTERA (code attached)
Hi dears. I am trying to use a (slightly) modified version of the UART explained in a tutorial I've found, after reading some theory about. There is one UART entity which has two c...
12 years ago --- Quote Start --- Yes, it is. You have separated out all of your combinatorial logic into one process, and then registered it in another. Aslong as they are placed in a clocked process that uses the correct clock, then its fine. --- Quote End ---
-- register byte_reg syncronized;
process(clk, reset) begin
if (reset = '1') then
state_reg <= idle;
baud_cnt_reg <= (others => '0');
bits_cnt_reg <= (others => '0');
byte_reg <= (others => '0');
elsif (clk'event and clk='1') then
state_reg <= state_next;
baud_cnt_reg <= baud_cnt_next;
bits_cnt_reg <= bits_cnt_next;
byte_reg <= byte_next;
end if;
end process;
-- left concatenate the new bit, assuming the bits are sent LSB to MSB
-- other process (FSM).
byte_next <= rx & byte_reg(7 downto 1);
-- out of any process, combinatorial logic.
-- Put the byte read on the output bus.
dout <= byte_reg;
