12 years agoUART and MODELSIM ALTERA (code attached)
Hi dears. I am trying to use a (slightly) modified version of the UART explained in a tutorial I've found, after reading some theory about. There is one UART entity which has two c...
12 years ago --- Quote Start --- just register them directly:
signal rd_r : std_logic_vector(1 downto 0);
signal serial_rx_r : std_logic_vector(1 downto 0);
process(clk)
begin
if rising_edge(clk) then
serial_rx_r <= serial_rx_r(0) & serial_rx;
rd_r <= rd_r(0) & rd;
end if;
end if;
Then use rd_r(1) instead of the origional input "rd" and the same for serial_rx --- Quote End --- Hi tricky, I am doing this already, for example, in the line 110 from the rx_uart.vhd: -- left concatenate the new bit, assuming the bits are sent LSB to MSB
byte_next <= rx & byte_reg(7 downto 1); Maybe the problem is with the FIFO megafunction? I am using the SCFIFO from altera. So, the input "rd" from this SCFIFO is connected with the output "rx_done_tick" from rx_uart.vhd. Maybe I should use the DCFIFO, which I read that it is better for deal with metastability. I noted too that the counter from mod_27.vhdl does not flash the leds to indicate that the counter inside is working. The outputs in this vhdl file are in this way: -- output logic
q <= std_logic_vector(r_reg);
max_tick <= '1' when r_reg=(M-1) else '0'; I think it should be corrected as you said. I'll try to double register these two outputs and test the counter first. Then I ll increment the circuitry with uart, then with the FIFO, and see if it works.
