12 years agoUART and MODELSIM ALTERA (code attached)
Hi dears. I am trying to use a (slightly) modified version of the UART explained in a tutorial I've found, after reading some theory about. There is one UART entity which has two c...
12 years agoThank Tricky, I will try it but, as soon as I am modeling the uart through Flip-Flops,
and using two signals to do in this way, I am thinking witch is the best practice to implement it. As a beginner Is it suggested to do it in the sequential logic process......or in the combinational part, outside the process? sequential logic process: entity ... port( rx: in std_logic ); ... archtecture ... -- two signals representing the Next State Logic register for a byte comming in port rx. signal b_reg, b_next: std_logic_vector(7 downto 0); -- other two signals representing the other register signal other_b_reg, other_b_next: std_logic_vector(7 downto 0); ... process(clk, reset) ... -- next state logic for b and... b_reg <= b_next; -- ...the other register. other_b_next <= b_reg;other_b_reg <= other_b_next; combinational logic: ... process(clk,rst) ... end process; ... process(sensitivity list) .... end process; ... --outside the process. b_reg <= b_next; other_b_next <= b_reg;
other_b_reg <= other_b_next; or even do i need another case statment in the finite state machine process just to pass the value from one signal to the other? It seems that we have a hot topic here (Views: >1,218). Thanks,
